Birdseye2411
First noticed the engine stutter or shake at idle on the way to ramp a while back. Flushed at home with no issues. A few weeks later ran offshore no issues. Fast forward to last weekend, started engine at home before setting off, no problem. At the ramp, first turn of the key, 1 rotation and nothing, like the batteries were dead. fooled with battery switch and engine started. left dock and noticed stuttering or shaking again. went to take off and motor bogged for a while. I checked primer ball and it was full, tried to plain again and motor bogged for about 30 seconds and then kicked in and jumped on plane and ran fine at top end. Anytime we stopped the same happened, bogging for about 30n seconds then takes off to WOT no problem. Back at home I noticed much more carbon or soot at exhaust. Any thoughts? I pulled the intake manifold to test the fuel lift pump since the oil looks thin and thought maybe it was allowing fuel into the block but no fuel leak there. I did find about 3 cups of water drained from intake manifold when I removed cover. Any thoughts on how the water got into the manifold and or why motor is bogging on takeoff? Also, is there a way to test the fuel pumps?
