Any reason you can't rebuild what you have now?
Crusader used a couple different pumps on the 8.1's...so not having the serial number doesn't help in identifying your specific pump.
Finally, crusader typically uses an 'off the shelf' (3rd party) pump vs getting a 'custom' made unit...many times, a close inspection of the existing pump will yield the make and model number and let you buy the the necessary parts from a wider supply base.
HI Mako, thanks for staying on this. The bearing assembly is common which is how I'm still running. The RA057035 number is cast into the pump along with "Pleasurecraft Engine Group" there is a stamped number "706D264" that doesn't yield anything usable on the web. The pre 05' 8.1's used a crank mounted raw water pump. Those motors also had crank position sensor issues and a few local mechanics think that maybe why they moved the pump off the crank ( a theory that's not completely crazy). I called Pleasurecraft and they were not helpful about the original supplier of the pump. Depco says NLA and had no other info. I'm going to pick up a Merc pump see if it's close enough or can be modified. Thanks for the feedback and keep it coming if you can. Best, Jim
Hi Bob, I see the retrofit to the crank as my worst case scenario... so that's not too bad. I love the way these motors perform, it's just a shame the support for them is rapidly fading out. Best, Jim
