Penta 380 outdrive tilt/trim not working
emac
when trying to use the tilt trim to raise the out drive, all I get is a "click" at the relay. I thought it was a bad relay, because at first if you wiggled the relay it would work. I replaced both relays and still only get the "click".
OK, ill check that out. I tried cleaning the inside where the relay plugs in with a toothbrush and wd40, that did not help.
