Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2020
    Location
    Outer Banks
    Posts
    5
    Default '00 Johnson 50hp Throttling Down
    Just recently, when I'm running at full throttle the motor will run fine for about 2-3 minutes and then it will start to throttle down on its own and throttle back up again. It doesn't feel like a "limp mode" feature because it doesn't stay in the throttle down position. See link below for the video, first throttle down is at 20 seconds.
    https://youtu.be/L80a7ZWuTqY
  2. #2
    Join Date
    Apr 2010
    Posts
    5,262
    Default Re: '00 Johnson 50hp Throttling Down
    Try a cylinder drop test on it when it acts up.
  3. #3
    Join Date
    Dec 2012
    Location
    newport news, va
    Posts
    307
    is primer bulb collapsing? also see you have a fuel filter, most also separate water from fuel, once full they pass water on to carb, (ask me how do i know this), remove and empty into glass jar, see what you get
  4. #4
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    4,415
    Great suggestions. I like the water diagnosis. Probably it's going to be fuel related. Do you use ethanol? You must know that it's hygroscopic. Since ethanol weighs only 6.5 lb per gallon it will displace its own weight in water and suspend that in your fuel. So a 13 gallon fresh10% ethanol fuel solution, (what you get at the pump for your car), will hold about a gallon of water allowing the motor to burn it. The filter/separator may trap some of that solution......even more critical as the fuel ages. Ethanol then is trapped which would be mixed with the water in your filter. Why should you know about this? It reduces the effective octane level in the fuel that reaches the motor, and that is not what the motor is engineered to burn. Did you know that pure, non-oxy (clear fuel), weighs only 6.1 pounds per gallon? It WILL NOT suspend ANY water. Then your filter/separator will do its job properly. How do I know this? My son is a chemist, specializing in fuels, propellants, and explosives.
Similar Threads
  1. Rattle when throttling off
    By Psycon in forum Johnson Evinrude Outboard Forum
    Last Post: 05-03-2021, 07:01 PM
  2. 2011 F50 stalls after throttling down
    By rejesterd in forum Yamaha Outboard Forum
    Last Post: 09-14-2018, 08:40 AM
  3. f30 stumble when throttling
    By Perrie in forum Yamaha Outboard Forum
    Last Post: 02-14-2017, 04:26 PM
  4. '81 70h.p. dies when throttling
    By Larboy8 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-25-2016, 10:08 PM
  5. Mercruiser 233 hp misses when throttling up
    By cctmedic52 in forum Mercury Mariner Outboard Archive
    Last Post: 07-15-2006, 12:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
