harvctry27
Hello I’m looking for an answer to probably something so simple that I’m over looking. I got in from fishing and in my rush hauling the boat out of the water on the ramp stupidly left the key on with battery’s still on. It took me a couple days to learn this and my battery’s went dead. Whoops never forget that again. Since then I’ve had a no start issue I’ve been try to diagnose. While trying to chase down the issue I have replaced plugs, fuel pump, plug wires, coil, distributor cap/rotor, oil pressure fuel cutoff switch and the 60 amp breaker. Still with no spark. So since that was the case I have a new ballast resistor coming tomorrow but I can’t see that being the fix. Motor cranks over great no issues and has good compression. It is an 05 5.7 carb. It does have a Mallory ignition as well which I have not replaced yet. What could I be missing here that I can’t think of?
