ksgoosekillr
Problem: Engine misses at various RPMs, can not get above 3-4000 RPMs.
Info:
Mercury Mariner 90Hp 3 cyl Serial ODOXXXXX
1 switchbox, 3 coils
18ft deep V, 17P prop.
Entire Elec Sys is now CDI
Tests done so far:
Compression Test: 120/120/115 PSI
Trigger: Passed all DVA tests
Stator: Passed Ohm and DVA tests *Have not tested for voltage drop while on water
Switchbox: Tested Coil DVA across outputs to coils, VRY ERRADIC READINGS. Tester gives off a spark when checking against grounds. Checked for voltage on kill switch .3VDC present. Removed wire and no change in performance.
Wires to coils: checked continuity across all and all good.
Regulator: passed all CDIs tests, bypassed regulator and removed all wires to see if that was issue. No change.
Coils: DVA tests good, same very erratic reading though and always get a spark against all grounds.
Wire: Checked continuity
Plugs: Cyl one showing a lean condition, 2 and 3 very wet. Able to jump 3/8” with a somewhat strong spark, still a little orange on cyl one.
Carbs: Rebuilt carbs, and inspected several times. Always spotless.
Fuel pump: Tested flow and amount seems to be within spec, Pressure is VERY erratic so hard to get a good reading. Pump has been rebuilt but had issues with check valves during rebuild. Pumping primer bulb during the max rpms around 3000rpms has no change in rpms leading me to think its elec. Enrichener during same time causes engine to stall.
Fuel tank: New pickup, cleared vent, even removed cap to check for vent issues.
Fuel: new 93 octane fuel
Timing: 2 deg at idle and 28 deg at WOT during cranking only, have not verified on water
Reed Valves: Visually inspected through plate, but have not tore down to actually inspect.
Ive tested for voltage to ground in tons of places to diag the spark im seeing when testing and can not find a measurable amount.
Im at my wits end with this engine, have done everything possible minus a few tests, sent switchbox, stator and trigger back to CDI to have them tested and all were reported to be good. Everything points to high speed winding on stator but OHMS good and supposedly tested good at CDI. Im two seconds from a match and phone call to State Farm. Suggestions other than bring smores to the fire?
Info:
Tests done so far:
