96 PCM 351 ignition parts - where to get?
kevinjgould
The 351 PCM in my 96 Boomerang has a screw on Prestolite distributor with what appears to be an electronic conversion inside. I need a new distributor cap and the guts inside the distributor including the electronic ignition set and the timing advance mechanism. NAPA is not able to find replacements (they show the Prestolite as no longer available). Any suggestions where I can go to find replacement parts or a new system? Thanks in advance. Kevin
Sierra makes most of the 'tune up' parts for prestolites as well but you may need the distributor number to look them up in the catalog.
The timing advance parts are much harder to find...the best bet is to find a local place that rebuilds distributors (the local hot rod shop can usually point you to a shop or two). The other option is to replace the whole thing and there are several options out there.
