Last summer I was trying to fix and diagnose some problems with my engine on this thread: http://www.marineengine.com/boat-forum/showthread.php?466248-Tohatsu-MD90A-surging-around-800-1000rpm&p=695407#post695407
I concluded that the diaphragm in my fuel regulator may have been broken which was causing the problems I was experiencing. Due to Corona, I was not able to get back to the boat until now and now I have some quarantine days to work on it again.
I did the following:
Engine started fine but after 15 minutes or so of running at idle or close to it, I pulled one of the plugs and it was still black and sooty. I was hoping that changing the fuel regulator would have fixed this but it seems not. My understanding is that they should not be sooty, even when running at idle.
I hope someone might be able to provide some more insight on what I should check next. Some questions:
Any help would be much appreciated. Thanks a lot in advance.
- Had injectors professionally cleaned.
- Replaced fuel regulator.
- Replaced fuel regulator hose with a non Tohatsu hose but I don't think this is an issue.
- Checked the thermostat is working correctly.
- Bought a new battery to make sure this is kicking out enough juice.
- Measured air rail air pressure at between about 72 and 78psi (it fluctuates from 72, up to 78 then down to 74 psi with the engine cycle, see notes below).
- Measured air rail fuel pressure at between 80 and 90 psi (it fluctuates from 84, up to 90 then down to 80psi in time with the engine cycle).
- Should the air and fuel pressure be pulsing like this? Here is a video of the air pressure (the fuel is similar, just 10psi higher): https://1drv.ms/v/s!AmWxme0O8FrMqkt87sLhzMJsrF-6 I assume that since the air compressor is a piston and the fuel pressure is dictated by the air pressure, both will exibit this pressure fluctuation. The video is not slow motion, but on my phone you can clearly see and hear that it fluctuates in time with the engine.
- Does it matter that my pressures seem to be a touch too low? It seems to be clear that the fuel is 10psi higher than the air, so this is good. I don't have access to shop air.
- I did not replace the Spark plugs with new ones, just cleaned them enough to really see the soot come back. I assume that brand new ones will just soot up again. Is this ok?
- Is it safe on a TLDI to pull the HT cords of the spark plugs one by one while the engine is running to make sure all cylinders are firing?
- What other things are worth checking before I get out of quarantine and get the boat on the water?
