I marked TDC for each cylinder on the flywheel.
When I hook up a timing light to the plug wires on cylinders 2 and 4 they both show to be firing on both cylinders 2&4 at TDC.
As in what i see when the light flashes is a mix of the numbers 2&4 flashing. Its really weird.
Cylinders 1 and 3 seem to be firing normal. As I only see a 1 or a 3 when the timing light is hooked up to eother of those plug wires. ANY HELP??
I already replaced the CDI with a brand new one. Same problem.
