Help with wiring
Avengeusa
Boat is a celebrity 181 1989 vintage
4.3l v6, not original engine
Bought the boat with a cracked block and heads
Built a motor, stuffed it in
When i got the boat the engine was mostly disassembled, all wires removed
Got it back together and am looking for help in finding out where a couple of sites go
1. The first wire is on the shift interrupter side in a sleeve with the temperature sensor wire, near cylinder#2 near the front of the block it's black with a loop, i have no idea where it goes
2. The second wire is on the rear of the engine by the ignition module, there is a small black wire with a loop
I'm trying to upload a couple pictures
Ayuh,..... Black wires are most likely/ should be Grounds,.....
The small one by the ignition module was, however in not sure about the cream colored one near cylinder number 2
Got it fired up
Now for the gimble bearing and bellows then if to the lake
The bilge pump works, but I need to check out the blower if i can find it, there is a switch for it
