Steffannalin
Long story on this, try to keep it short: Twin 150's, use for pleasure, hunting, commercial salmon troll in SE Alaska. 788 hours on both, swap engines while trolling to keep hours down/even. Keep all maintenance up, marine diesel mech/welder by trade, so not lost under the hood. The electronics being what they are, and unable to find a DTC tool for this year/model is frustrating. Set valve lash on time, change thermostats per the schedule, impellers, etc..
Headed out to fish last Friday and lost power while on plane, could tell port engine was lagging...pull back throttles and port engine stalls. Scroll through menu on combo tach, temp gauge says 242 degrees! Panic, only imagine that I've warped a head (previous power was twin 130's, unbeknownst wrapped kelp on intake and smoked the starboard engine in 2014). Pull dipstick, all good. Cruised back to port on starboard and by time I got there the temp was down to 170 so tried to restart. Ran fine, temp came down further, so figured a stuck thermostat (had 89 hours on current stats), so called dealer in Sitka and ordered two sets and had them air freighted over to not miss more days on the water. Replaced and ran in driveway fine.
Go fishing Sunday and all seems norm...run to spot to fish, 30 minute ride, and pull back throttles...port engine had crept up over 200 again...idling comes down under 165...fished all day. Return to port had to continue to slow down to allow to cool, then back up to plane, etc...long trip home.
Go fishing Monday and same thing, after confirming Sunday night thermostats were operating as designed with a thermometer and hot water. All good. On return to port Monday, engine stalls when pulling back to N. Alarm goes off before it dies, no indicator which alarm. Shut down, restarts fine.
Pull lower unit, replace impeller with new one, hook up a sump pump, pull thermostats, and back flush with salt away and 10 gallons water for 5 hours. Reinstall everything, shunt out the data plug (another thread here suggested) and did the key click counting flashes...confusing flashes. One long, 2 short. One long 5 short. One long 7 short? Maybe? Cleared them, no new codes. Run engine with lower unit back on, and idles fine. Take up to 1600 rpm, all seems great. Cycle throttle up over 2000, reach 3000 and hold for 5 seconds or so, bring back down and low oil pressure alarm goes off. WTF! Shut down, restart, no alarm. Shunt data plug, no code.
Completely at a loss. Have tested both ECT's, ohm'd out normal for cold water hot water best I can tell. Haven't done anything with the oil pressure sensor/sending unit.
ANY help is greatly appreciated!
