If and neutral it will not go past half throttle before it dies and in gear it just diesI assume what you are saying is that your motor will run in neutral at a high rpm but when you bring it to an idle it will die. And if you can get the rpm low enough to put it in gear it will die. Is this correct?
Just had it serviced and the carburetor gone through still doing itDo you run fuel out of the carburetor at the end of your boating activity ?----Or when motor sits for a week or more ?
