Hoping someone can help. Since this 2010 Mercury is really a Tohatsu, I'll try this forum instead of Merc (tried it there but got no hits).
Issue: Running boat in water causes water pressure from tell tale to drop off and become weak. Motor will eventually heat up. Had one overheat alarm (the first time). If you shut motor down, water pressure returns and appears normal. Is also normal in neutral with higher RPMs as well, issue only seems to develop when underway. I made sure the pickup screens are not blocked or tubes clogged, and made sure intake screens were on the proper way.
I suspected water pump cavitation. I have entirely replaced the water pump including upper and lower housings, gaskets, wear plate, cup, impeller and key. I also added the rubber centrifugal slinger on shaft that is shown in parts diagrams (part is NLA but I found a grommet that worked). I also replaced the thermostat and flushed the motor with it out. Motor still does it.
When running at dock, water stream heats up to approx 95-100 degrees and doesn't seem to get hotter. I blew out all the water passages as best I understood them and don't believe anything is clogged. If there is, it's a passage I'm not aware of.
Could this be a leaking exhaust gasket? Could exhaust be entering the water jacket and causing pressure issues? Would there be other symptoms I could look for? It's frustrating to test, as you have to have the boat in the water and underway for it to do it. Works completely fine in the bucket, at least I think it is. I can't find a mechanic that has time to look at it now, so trying to get it solved on my own. I'm handy, but feel like I'm out of ideas.
Thanks.
Thanks.
