I'm trying to tune the carbs on my 90 (non TLDI obviously) as per the factory service manual and wondering if there is any advice.
I did the link, sync and timing as per the manual, now onto setting the idle and the mixture screws. The issue I have is that I can't get the engine to idle at 1100 rpm in neutral/900 in gear. If I tune it for 900 in gear, it idles at nearly 1500 in neutral. If I tune it for 1100 in neutral, it will drop down to 6-700 in gear. This is being done in the water, not tied to a dock etc (boat moving). How do you guys usually set these up? Any issues with running the idle down to 6-700 in gear? It seems to run fine at those speeds (doesn't stall).
Thanks...
Thanks...
