i am working on a 2008 marine power and it started fine this season, but once in the water she died after running like crap, now i get no crank, dash info says no power detected from ECM. i
also, if anyone knows were the engine info is located, i would like to see that as well. its a small block engine so im guessing its a 6.0
i checked power the the main breaker on top of the engine, thats ok, battery is good, i jumped the starter and the engine spins. but turning the key gets nothing, no fuel pump hum, no solenoids clicking.
after a deep search, i finally found the DLC and scanner read " no ecm detected" , so i am now trying to run down why suddenly she would run poorly and then shut down completely with no power to ecm after that.
im not sure if this is a MEFI 4,5 or 6. i don't think is a 6 because that diagram shows individual coil packs.
the one i have has the traditional crap style distributor/cap
thanks guys
thanks guys
