I am working on a 1959 evinrude sportwin and I finished up rebuilding the carb, resealing the lower unit and gear case. I set the low (1-1/2) and high speed needles (3/4) to factory settings and it does start up easily. However the motor dies right before i even throttle it down from the start position(which actually starts more in the run position) to the shift setting to put it in gear (forward or reverse). I have started up the motor in forward gear and it doesn't seem to get up to full speed (rpm). I ran it for 10 min in the tank and when I throttled it down and right before it got to the shift position it died (multiple times). It runs alright with a slight vibration but it doesn't rev up near as far as it should go. I did replace the plugs as well. The pressure tank was all redone with new gas/air lines. Fuel mix is 24:1 with new premium gas. i am looking for assistance on what can be causing this as well ways to fix it. Thoughts and suggestions?
