S_Evanitus
I have done a lot of reading on the forums. I ohm tested the forward coil and it was 5.9, I also tested the control switch in the throttle and it is functioning correctly. I have reverse, and I drained and served the lower to no avail. My question is, is it the forward clutch spring? Or is there something else I need to check before I go inside this beast?
