Have a Evinrude 30hp Model E30TELCED, 1989, that is leaking oil where the lower unit is attached to the shaft section; and, the lower unit oil is turning from a deep blue to a light blue color after running it on the lake. Would it be a good idea to change out the water pump with Sierra 18-3382? Do I need to do a pressure test first on the lower unit? The water pump has not been changed in a few years, even by previous owner. What other lower unit seals, by the water pump, should I also replace?
Also what other seals, gaskets, or o-rings should I replace for the oil leak, just above where the lower unit is attached? Been looking on the illustrated sections provided through Marineengine.com. Still learning the ropes of all this neat stuff.
Just now starting to work on my outboard motors for the first time. FUN stuff!
