Power coil tests for ohm readings in service manual pass and static short to ground tests pass. When connecting brown and brown/yellow to ground through volt meter there is voltage read on both of them during cranking. Replaced the power coil and have same thing. What could cause the power coil to short to ground only when cranking the engine?
