Tohatsu tldi 90hp model 2007
vaggelis
Hello I am having a problem I moved the boat battery to the front and added 4 meters of battery cable. After that, opening the switch of the machine and after making the check, the three bulbs remain on, what happens?
What is your actual model? What size is the battery? Does the motor start? "opening" a switch means to shut it off; I assume you mean you turn it on. Do the 3 lights flash, or are the continuous?
