As of last weekend, the 2 solenoids for the tilt motor stopped working. I've removed both solenoids and bench tested them by providing power directly from the battery. 12v supplied to the solenoid, and to the switch post correctly activates the tilt motor as it should. Both work fine, however when they are mounted to the motor and grounded through the mount bracket, the switch post reads only about 10.5v. I'm losing pretty much 2v through to ground I believe, but I'm not sure how to begin testing for this. Thanks!
