I hear a loud noise that sounds like it could be at the rear of the engine. I removed the belt and spun and wriggled each pulley by hand; each was tight and smooth w/o any noise. I put the muffs on and fired up the engine. I used a stethoscope to check each moving part up front; all ok. I checked the OD at various points including the gimbal bearing but no bearing noise. I'm guessing it's the engine coupler? I'm going to try to grease the coupler but it is hard to get to due to boat design. While in the water the other day there seemed to be a vibration through the hull. Engine mounts seemed to be ok...engine was not shaking at idle. Any thoughts or suggestions would be appreciated. Thanks in advance.
