[FONT="]Theboat started and ran fine at the close of last year.[/FONT][FONT="][/FONT]
[FONT="] [/FONT][FONT="][/FONT]
[FONT="]When I go to start it, it turns over strong but will not start. Two distinct things are missing:[/FONT][FONT="][/FONT]
[FONT="]1. no fuel pump priming[/FONT][FONT="][/FONT]
[FONT="]2. no alarm test sound on start[/FONT][FONT="][/FONT]
[FONT="]So far I have tried:[/FONT][FONT="][/FONT]
[FONT="]1. I checked all the fuses. [/FONT][FONT="][/FONT]
[FONT="]2. The outdrive trims up and down strong. (suggesting goodbattery and voltage)[/FONT][FONT="][/FONT]
[FONT="]3. I cleaned the fuel pump relays[/FONT][FONT="][/FONT]
[FONT="]4. I changed out the fuel pump relays with the trim relays(trim still works strong)[/FONT][FONT="][/FONT]
[FONT="]5. I have checked for voltage at pins 86 and 30 on fuelrelay slots (good)[/FONT][FONT="][/FONT]
[FONT="]6. I have tested for continuity between pin 87 on fuelrelay slot and fuel pumps (good)[/FONT][FONT="][/FONT]
[FONT="]7. I powered pins 87 (fuel pump relay slot) with my powerprobe 3 - fuel pumps made noise[/FONT][FONT="][/FONT]
[FONT="]8. I changed the Engine Coolant Temperature Switch -(no help)[/FONT][FONT="][/FONT]
[FONT="]Code Scan tools are expensive, so I was going to try thisapproach I found on youtube:[/FONT][FONT="][/FONT]
[FONT="]https://www.youtube.com/watch?v=woawMujBpFY[/FONT][FONT="][/FONT]
[FONT="]Is there a belter way to read the DTC codes?[/FONT][FONT="][/FONT]
[FONT="]I was going to replace the Oil Pressure switch but I can't findit. Does anyone no where it's located? I found the oil pressuresender but not the switch.[/FONT][FONT="][/FONT]
[FONT="]Any help with trouble shooting this would be greatlyappreciated.[/FONT][FONT="][/FONT]
[FONT="]Thank you, [/FONT][FONT="][/FONT]
[FONT="]Kevin[/FONT][FONT="][/FONT]
