Hello guys,
I'm seeking advice on this Mercury (Motor code is 66M)
The Motor has good leakdown values and runs very well.
The strange thing is that it would only have an intermittend telltale at idle, which leads to overheating eventually.
If you give it some revs the telltale gets stronger and the motor doesn't overheat any more.
-Thermostat checked fine
-Impeller and water pump is brand new
-Copper tube is connected correctly and doesn't leak
Here is what I found. If I take off the muffler plate at the back (behind it is the exhaust chest where water and exhaust mix) the telltale steadies and the motor doesn't overheat anymore. Problem is now it sounds like a top fuel dragster
I'm suspecting an exhaust leak into the water jacket now. Theory being that the leak gets better when exhaust backpressure is reduced.
Any ideas? Thanks alot in advance, I'm curious what will turn out to be the problem.
