Trolling motor cuts off in higher speed
Moose8383
I have a Minn Kota Riptide 55 pound thrust with a pilot that will run in higher speeds for a minute and shakes and cuts off can I unplug from power source plug back in and will work again but Runs fine in lower speeds work that be
Do you have an inline relay? Most electric motors do. At full load the motor may draw too many amps for the relay. It trips and then cools down and self resets. You may have a weak relay that needs replacement or the wiring to the battery may be too small.
