Results 1 to 2 of 2
    Default Can't pull engine over with compression tester fitted
    Hi all,
    I was servicing a Yamaha 2-stroke 4hp (4AC) the other day. It's is now running completely fine after fixing a few problems. Thought I'd do a quick compression test just to see, but with the compression tester in, I couldn't pull the engine over at all. There was so much resistance that I'm convinced the pull start cord would have snapped if I tried any harder.
    Has anyone ever experienced this before? My only thought was that maybe the thread on the compression tester was long enough to foul the piston, but it doesn't seem that much longer than the spark plug.
    Jun 2013
    Duluth Mn
    4,237
    Default Re: Can't pull engine over with compression tester fitted
    Welcome. How bout if you back out the tester a few revolutions and try again?
  1. Piston hit compression tester adapter....
    By cjbrill715 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-11-2019, 03:33 PM
  2. Compression tester fittings
    By Chillywilly in forum Yamaha Outboard Forum
    Last Post: 06-03-2015, 09:03 PM
  3. Compression tester for 2712e & new injectors
    By Tom Pa in forum Ford Lehman
    Last Post: 12-17-2012, 04:47 PM
  4. Sad News from Compression Tester
    By ezuskin in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 04-20-2009, 12:25 PM
  5. 41078 Compression tester
    By crzhors in forum Perkins
    Last Post: 12-31-1969, 07:00 PM
