BF 225 Changing from a 25" to 30" Leg Help
seaox23
Hey guys new here looking to change my 25" Leg to a 30" leg on a 04 BF225. i Have the 30" leg and the spacer just looking to see what i will need for hardware. i have called the dealership but it looks like the studs are no longer avaiable anychance someone would have a part number or anyinfo on this.
I just converted a pair of 50's 25">20". In addition to the leg extension, we were talking studs of course, then lower shift shaft, water tube, and drive shaft. Changing the drive shaft involved pulling the lower completely down to get to the pinion nut. Then, the big housing under the motor had to be removed long enough to change the water tube! Point being, it was way a bigger job than I thought it would be!
