Results 1 to 2 of 2
    Default Remote Control Stiff
    2005 Triton aluminum V hull with Johnson (Suzuki) 140.
    I am unable to identify the make of the remote control, but have pictures. I have loosened the carpeted plate with the control from the side location, however I cannot see how to remove five screws holding the control to that plate. The heads are behind the cover behind the lever and I don't see how to remove that cover.
    Trying to post two pics, but I don't think it worked. Couldn't find instructions in search
    Jim
    Sep 2008
    Maryland - USA
    8,666
    Default Re: Remote Control Stiff
    Look here for posting pics:
    http://www.marineengine.com/boat-for...b3_attachments
    from what I recall, you need five posts BEFORE you can add an image...I'd suggest adding some 'dummy' posts in the section where you can practice...go to the forum home page and scroll down to the bottom...
  1. Stiff throttle cable in remote control, no fast idle
    By coteno47 in forum Mercury Mariner Outboard Forum
    Last Post: 03-29-2020, 08:10 AM
  2. 1985 Evinrude 15 hp Stiff Twist Grip Throttle Control
    By Swarlos in forum Johnson Evinrude Outboard Forum
    Last Post: 10-06-2019, 09:25 AM
  3. Johnson Remote Control Compatibility - Can I use a 115hp control with a 70hp control?
    By jimklar in forum Miscellaneous marine engine topics
    Last Post: 06-11-2017, 02:06 PM
  4. Control cables are stiff
    By damroc in forum Mercruiser Sterndrive Forum
    Last Post: 10-04-2009, 01:08 AM
  5. Stiff throttle control
    By chad myrvik in forum Mercury Mariner Outboard Archive
    Last Post: 04-05-2008, 05:26 AM
