Getting trickle of coolant water from below middle of port side lower cowl. Only rust that can be seen is those two bolts, one over the other, so think perhaps leak is from that part or a hose raining on that area.Need help identifying this part which is located at bottom of 2003 Honda 225 just to port from center of rear of engine.
Keeping in mind that the cooling water is sent through the system with some force, a leak could not only be coming from above but from below or from the side as well.
What outboard are we looking at? Knowing that piece of info might help someone help you.
Good luck.
