I have a bravo 3 im doing someone a favor fixing. I normally work on larger diesels so I need some advice. I changed the yoke end and yoke seal on a bravo 3 drive and then set the rolling torque. When I tighten the retainer nut to 125 lb/ft (as per manual) the gears bind and the driveshaft barely spins. Anyone have any ideas? I installed everything correctly. Also- is the spacer between the gears supposed to spin freely? I know they are pressed onto the pinion but the current one does not spin freely. Any input is appreciated. I attached a picture of the bearings i have.
