Got a new to me 2005 SeaRay with a 4.3MPI. Last fall I was winterizing it for the first time. I opened the single point drain and let it drain and then saw there was a blue drain plug right above where the drainhose was so I opened that as well and let it drain (nothing really came out of that). I closed the single point drain and replaced the blue drain plug above the drain hose housing. I then hooked up the ear muffs and began pumping in the pink antifreeze and thats when I noticed there was a drip coming from the blue drain plug above the drain hose. I tightened it as tight as I could but couldnt get it to stop.
I went to the boat shop and picked up a new blue drain plug and replaced it but it still was dripping. I took a round wire brush and removed the new drain plug and cleaned out the hole and checked the plug to make sure it was good and replaced it but still was dripping.
Called the boat shop today and they said they are 8 weeks out before they can look at it. Any ideas why it is leaking and how to stop it?
