Freshly rebuilt motor started readily but it is idling too high, somewhere around 2K RPM's (estimate) on the muffs. The tach on the boat is not working correctly, showing 6K, bouncing down to 4K intermittently.
I understand idle speed is supposed to be set on the water, in gear and I will do that later but I want to do the entire timing/carb synch procedure and get the idle speed in the ballpark as well. About what RPM should I set it to when idling in neutral on muffs to be close?
Is it possible to hook up an old school dwell/tach to this motor? I have attached an image of a Penske/Sears Dwell Tachometer. If this old meter won't work can anyone suggest a reasonably priced alternative? Not to replace the boat tach but to use for tuneup procedures.
Of course I also want to fix the tach on the boat. Is there a way to determine if the guage is bad vs. some kind of wiring issue?
