Before I replaced my water pump on my 80 hp out board motor neutral and reverse work fine, I put it in forward gear before removing it when I tried putting it back in I turn the prop, it still would not go in so I move the shift and kelp adjust it it finally went back in, now my problem is it stays in forward gear will not go in neutral nor reverse I need help can someone tell me what I need to do to fix
