yes it is straight gloss black. Also, they recommend spraying the 2 part clear coat within 2 hours of applying the last coat, how would I buff it with scotch brite then? Or should the paint be dry enough before 2 hours that I could buff it with the scotch brite pad? What I might just do is rough up all the paint with some sand paper, black gloss automotive paint,primer, 2 part clear coat. Then either keep decals or buy new ones.Yes, you could simply touch up the scratches, being careful not to damage the decals, and then the clear would smooth everything over. This type of touch up takes some experience so it might be hard for you to do. I do it quite often with Mercury's because they are a straight black color. So I am only feathering the scratches by hand with wet or dry paper, then priming only the feathered spots, then touching up with the black rattle can, while saving the decals. Then I lightly buff the entire motor with a medium grit Scotch-Brite and using water. Then cover spray with the epoxy clear. You get dramatic results, without completely covering the original finish with black. The clear also restores luster to the decals. I think that 20 is straight gloss black, right?
I just popped the lower unit off the Martin, completely seized. Power head is fine though, where should I go from here? Start taking apart the lower unit or just find a replacement?All shafts have bearings of some sort !!---Some shaft have rubber bearings and are lubricated by water.---Just a simple matter of designing for the conditions that exist.
Where should I put some pb blaster? I have some in the lower end and I'm thinking about temporarily plugging the water drain for the LU to fill that area up. It does move a little but that could just be some play in between the gears.Putting a wrench & twisting right now is the wrong approach. That is a guaranteed SNAFU.
While you’re looking for a used lower end, soak it like Tim said. BE PATIENT. After a day or two, try turning back/fwd, just a little. If it moves, let it soak some more, repeat.
Sometimes you get lucky, patience is a virtue here, & you’ve got plenty of time while looking for a used part.
