My boat was sitting for 4 months without running. Last time I used it in August it lost power on the high end. Last week I just put a new high pressure pump and VST filter on the engine started it, let it idle ,all seemed fine. When I went to lift the engine the trim/tilt motor ran down but not up. I replaced the relay it ran fine. Then I notice my helm was bad replace that. I took it to launch it. Started the engine all seemed fine at idle. I pushed the neutral switch in just to test it at higher rpm and the engine cut out. It would not crank and trim tilt did not work. Now it keeps blowing a 30 amp glass fuse back by the trim tilt fuses which are ok. If we don't turn the key the fuse stays and trim tilt works. But as soon as the ignition is turn on it blows the fuse. Someone is looking at it for me at this point but any help is appreciated. Thanks, Alan
