Click for Honda Manuals, Parts and Model Guides!
Results 1 to 22 of 22
  1. #1
    Default BF 200 Power loss
    I have an 04 BF 200 that had the fuel system replaced 3 years ago due to loss of power that turned out to be corrosion in the high pressure fuel pump. (used ethanol gas) since then its run at least once a month and with only good gas (non ethanol 93 octane) I drained the gas out of the tank as it was in there for some time and had it set up to run on gas can. my son took it out and decided to fill the main tank 80 gal ran half of it out running good. Took it out two weeks later. Loading CC he disconnected a ground for the gauges (didn't know this at the time) filled back up but took it out with out gauges. Ran great at the end of the day it wouldn't plane or go up above 2k, no lights beeping nothing. After getting it back I find the wire disconnected gauges work and was almost empty. Hoped he just ran it to low hooked up can again no power, replaced low pressure filter (some dirt) high pressure and vast are clean still no power. Plugs look good compression is good fuel bulb is firm nothing happens when pumped. IAB was a little sticky.
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,964
    Default Re: BF 200 Power loss
    Give more detail on your statement: "hooked up can again no power"
    Top of mind...
    First - check your kill switch. Work it back and forth a bunch of times, then set the yoke and try again.
    When you first turn on the key switch, can you hear the fuel pump come on for about 2 seconds?
    Check your fuses. Don't just look at them, but test each for continuity and no discernable resistance.
    Drain the VST to make sure that low fuel didn't suck water into the VST.
    The IAB will not interfere with starting. It kicks in at 3800 rpm.
    CHawk 25 DLX
  3. #3
    After I got the boat back and found the cause of no gauges I saw it was very low on gas. Hoped the little fuel was moving away from pick up when trying to plane. I hooked up a gas can no luck, drained vast replaced both filters the low pressure had some debris in it. Still no luck, cleaned /checked filter again and drained vast no dirt or water. starts and runs fin with muffs on. No luck on the water pulled plugs there good spun motor with pressure gauge lowest was 185 IAB was sticking so lubed that working good now. Fresh gas can revs fine but still under load it starts fumbling at 2k and throttle doesn't effect it
  4. #4
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    OK.
    When running the boat, and it bogs down, have you tried rapidly pumping the primer bulb to see if it clears up? If not, try that. If that temporarily fixes the problem, you could have a failing low pressure fuel pump.
    Look at the low pressure filter bowl when it acts up. It should stay at least 1/3 full. If not, you may have a restriction in the fuel line.
    Check it, especially where it feeds into the big black grommet where it enters the engine compartment. Corrosion can build up in there and restrict fuel flow.
    Another possibility is that your fuel pick up tube in the fuel tank is partially clogged. Pull it and clean the screen that is on the end. (If there is debris in the tank and you ran it very low on fuel, this is a distinct possibility.)
    If none of that addresses the problem check your fuel pressure. You attach your fuel pressure gauge to the pressure relief bolt on top of the HP fuel filter cover. You will need a 6 mm adaptor. At idle, with the vacuum tube removed from the fuel pressure regulator and clamped shut, fuel pressure should read 41 to 48 psi. If it is over that, then there is a screen on the fuel pressure regulator that may need to be cleaned. If it is under that, there is a screen on the bottom of the HP fuel pump holder that may need to be cleaned and possibly replaced because it's a real PITA to get it out.
    See this description of the fuel filters and screens on this engine: Fuel filters and screens on BF 200 and BF 225.pdf
    CHawk 25 DLX
  5. #5
    I'll have to find the adapters to test the pressure. The low pressure bowl stays full used to be like 1/3 is that an indication of something?
  6. #6
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    I've never seen mine be completely full when engine is running. I'm guessing here, but if the LP pump is pulling fuel from the tank but there is a restriction somewhere downstream of the LP pump, that would keep the LP filter bowl filled up. That could be caused by a failing HP fuel pump, a clogged screen under that fuel pump, a clogged or dirty fuel regulator, a sticking float valve in the VST, or several other things.
    If you measure fuel pressure as described before, that may help you isolate the problem.
    CHawk 25 DLX
  7. #7
    That's what I'm afraid of, having to get into the high pressure fuel side again. It was all replaced not 3 years ago and it isn't cheep, not to mention the labor costs.
  8. #8
    Is there way to blow the fuel lines out from say the injector line to the VST ?
  9. #9
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    Hmmmm! Never considered that. What would you be accomplishing by doing that? If there were obstructions in the fuel lines or filter screens that you would be trying to blow out, they would just end up somewhere else in the system. If you disconnected the feed to the fuel pressure regulator from the HP fuel pump, that could possibly clear the fuel pressure regulator, but not even sure of that.
    CHawk 25 DLX
  10. #10
    Just thinking out loud sort of. I got looking at it again after another failed attempt and found more debris in the low pressure bowl. I drained the VST again and looked closer at it, found some very small sand like stuff in it. So was had a thought if I could blow the lines out backwards it might help without tearing it apart. can you recommend a good pressure tester seems I'm needing one. Found a service workshop manual for it so that will help also
  11. #11
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    If you got more debris in the LP filter bowl, then your problem is upstream - either dirty fuel tank or deteriorating fuel lines. Do you have an external fuel/water separator (e.g. Racor?) If so, when is the last time the filter was changed? They should be drained every 50 hours or so and replaced annually. If you don't have one, consider installing one. That will go a long way in keeping the rest of your fuel feed system clean.
    However, you likely still have junk in your fuel system. You probably need to pull the VST, clean it out, carefully check the float value and re-set the float to spec. If I were doing that, I would just replace the float valve. And it would be wise to pull the HP fuel pump holder and clean that screen on the bottom.
    CHawk 25 DLX
  12. #12
    can you recommended a fuel test kit that has the adapter in it (6mm). I see a lot out there but seem to be more for cars and nothing says what size adapters come with them. If I have to wait for something to show up I'd like to know it has what I need rather than have to find it and wait some more.
  13. #13
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    Just about any auto fuel pressure gauge will do and most auto parts stores should have an adaptor. I think most of the fuel pressure gauges come with a 1/8" or 1/4" NPT thread.
    The gauge I use is a USG. Don't remember where i bought it or the adaptor.
    CHawk 25 DLX
  14. #14
    Ordered a test gauge kit and a few filters when it all comes in I'll play some more
  15. #15
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    OK. Keep us posted on your progress.
    CHawk 25 DLX
  16. #16
    I just got the gauge and hooked it up to the filter port on the high pressure side it tops out at 42-5 then back to 0 but I didn't start it. The filters and seals should be here in a day or so. How far do I have to take it apart to get to the regulator?
  17. #17
    Couldn't wait reads 35 at idle without the line clamped if it has one (picture I looked at didn't show a vacuum line) but I did get glimpse of it I think (Lt side top behind the intake)
  18. #18
  19. #19
    Okgot the tester and time it reads 44 at idle any ideas
  20. #20
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    See my post #11.
    CHawk 25 DLX
  21. #21
    Is there something else that could cause this (timing / safe mode) you shouldn't have to change the filters more then you check the air in the tires.
    I have replaced the low pressure and high pressure filters before the season and after the issue presented and just now again with the shipment of the tester also have been running from a separate gas source not the main tank (since that post) that also has an added filter prior to the engine. The test showed good pressure and by your post #4 there shouldn't be screen/ debris issue.
  22. #22
    Join Date
    Sep 2008
    Location
    Posts
    4,964
    Have you tried pulling fault codes?
    CHawk 25 DLX
Similar Threads
  1. Merc.50 power loss, power gain, loss, gain??
    By shlimshlam in forum Mercury Mariner Outboard Forum
    Last Post: 04-16-2012, 01:22 PM
  2. Top End Power Loss on 30 HP
    By fishin_bug in forum Yamaha Outboard Forum
    Last Post: 06-14-2010, 11:44 AM
  3. Power loss
    By bjt in forum Mercruiser Sterndrive Archive
    Last Post: 05-29-2008, 01:23 PM
  4. Loss of power or interupted power
    By toad in forum Chrysler Force Outboard Archive
    Last Post: 11-04-2007, 01:15 AM
  5. OMC 38 power loss
    By Jerry Dabkowski in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-06-2006, 05:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
