Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 8 of 8
    Default 2000 NS3.5B 2 stroke low compression
    This motor was originally purchased by my parents in 2000, they used it for 2 years before it sat in storage for a long time. I took it out recently and tried to fire it up with some fresh 50:1 mix, but it wouldn't start. Compression test showed low compression, about 40-50 PSI. Took the powerhead apart, found the piston ring was stuck in the groove, broke it trying to take it out and replaced it with a new OEM one (made sure it could move freely). Piston itself and cylinder walls looked to be in good condition, as well as the intake reed valve, so I did not replace those. Replaced the crankshaft oil seals, cylinder head gasket, drive shaft housing gasket and spark plug. After all this, I still only get around 50 psi, and when I spin the flywheel with a drill the motor almost wants to fire when I have the carb 3/4 full choke. Seems like somewhere compression is leaking but I'm stumped. I bought a cylinder leak down testing tool, and when the piston is TDC it holds pressure. Any help or suggestions on where to look next would be appreciated. At this point I'm wondering if the cylinder walls are out of spec or I need a new piston (isn't just the piston ring doing the real sealing work against the walls using a film of oil)?
    Mar 2010
    Hamburg, NY, USA
    3,053
    Default Re: 2000 NS3.5B 2 stroke low compression
    Should fire up, even at 50 psi. Then run to seat the new rings.
    Paul
    Certified Tohatsu TLDI Technician
    Hamburg, NY USA
    Jun 2013
    Duluth Mn
    3,521
    Does spark jump 7/16" with a nice blue/white crackle? I'm sure you tried to prime it? Yes, as Paul said....it should start at 50 psi. Once fired up, you may need to clean carb...depending on how it was stored.
    Mar 2010
    Hamburg, NY, USA
    3,053
    Yep. Odds are the carb is funky.
    Paul
    Hamburg, NY USA
    Tried again today and cranked up to 75 psi!! Was able to get the engine to turn over, although she still seems to like a richer mix right now. Running with 25-30:1 mix for break in at low rpm. One other issue currently is, I broke a head bolt when attempting to replace the head gasket, and then broke a high speed steel drill bit trying to drill out the broken bolt. I currently have only 3 head bolts installed, and I see a little weeping from the head gasket area. Seems like I'll need to find a machine shop or someone to extract that drill bit and install all 4 head bolts.
  6. #6
    Managed to punch out the broken drill bit and tap new threads, all 4 head bolts installed and torqued to spec. No more weeping from head gasket! Thanks Paul and Tim for helping to troubleshoot and resurrect this motor. Can't wait to try it out on the river once the weather warms up!
  7. #7
    One last question, I broke the #4 gasket sealing powerhead to driveshaft housing during disassembly and resealed the two surfaces uses high temp permatex red silicone RTV, which seems to be holding fine. However, the instructions say not to use silicone RTV where gasoline can contact. That area has water passages and the exhaust passage, will the seal eventually fail from exposure to unburnt gas vapors in the two stroke exhaust? Is it ok to use RTV?
  8. #8
    Mar 2010
    Hamburg, NY, USA
    3,053
    I would probably install a new gasket.
    Paul
    Hamburg, NY USA
  1. 2000 Evinrude (Suzuki) 50 HP 4 stroke engine compression range
    By sledman1 in forum Suzuki Outboard Forum
    Last Post: 04-14-2018, 10:21 PM
  2. 2000 Evinrude 50 HP 4 stroke engine compression range
    By sledman1 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-20-2018, 02:12 PM
  3. 2000 Evinrude (Suzuki) 50 HP 4 stroke engine compression range
    Last Post: 02-15-2018, 01:57 PM
  4. Thoughts on Compression Readings on 2000 Mercury 90hp 4-Stroke
    By thompsdw in forum Mercury Mariner Outboard Forum
    Last Post: 09-28-2014, 12:30 PM
  5. Still have water leak compression good 2000 40 hp 4 stroke
    By pop1198 in forum Suzuki Outboard Archive
    Last Post: 07-25-2008, 02:34 AM
