Results 1 to 3 of 3
    Default Installing fuel/water separator
    The top of my gas tank is approx 6 inches lower than my f50 yamaha and I want to add a fuel/water separator.&nbsp; I will have to mount this filter where the fuel will have to travel up about 4 more inches through the filter and then back down to the motor.&nbsp; Would this higher routing put additional stress on the fuel pump?&nbsp;&nbsp;<br><br>
    Sep 2008
    Maryland - USA
    8,542
    Default Re: Installing fuel/water separator
    It will make the pump work 'a little bit harder' but should be well within the pump's operating region...
    Dec 2006
    Greenfield Me. USA
    6,105
    Ayuh,...... It'll work, just fine,.....
  1. Fuel water separator
    By Peterpd99 in forum Johnson Evinrude Outboard Forum
    Last Post: 11-24-2017, 09:24 AM
  2. Replies: 7
    Last Post: 08-11-2016, 06:55 PM
  3. fuel/water separator
    By kcdbrian in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-16-2012, 08:39 PM
  4. fuel filter/water separator fo premixed fuel 85hp
    By bredfan in forum Johnson Evinrude Outboard Forum
    Last Post: 09-02-2010, 04:23 PM
  5. Fuel water separator or just fuel line with filter on AQ125B
    By Javier Cubero in forum Volvo Penta Gas Archive
    Last Post: 10-17-2006, 08:39 PM
