Results 1 to 2 of 2
    Apr 2019
    Arizona
    84
    Default Installing Transom Saver on Bayliner Trailer
    This, I believe, is the original "Escort" trailer for my 1985 Bayliner Capri Cuddy boat. I found a "SeaSense" transom saver online, and later realized that the trailer axle is about 6 feet away from the outboard motor. After consulting with a local boat shop in Arizona, I decided to fabricate a support beam for the transom saver. I got some aluminum square bar and some steel channel bar from a metal yard and fabricated the support beam. I was also told by the boat mechanic that installing a "roller" on the beam might help to mount the transom saver. I actually bolted the assembly right to the support beam. I used grade 5 1/4"x20, 5/16" and 3/8" bolts for the installation. I hope it will make it o.k. to the lake.
ID:	25421Click image for larger version.
ID:	25423Click image for larger version.
ID:	25422Click image for larger version.
ID:	25424Click image for larger version.
    Apr 2019
    Arizona
    84
    Default Re: Installing Transom Saver on Bayliner Trailer
    The same setup is going to work for my 85 h.p. Evinrude V-4? I sure hope so... "boatdokker"
  1. Locking Transom Saver
    By Joe Leja in forum Mercury Mariner Outboard Forum
    Last Post: 08-16-2012, 12:49 PM
  2. Transum saver for an 84 Bayliner Capri
    By Ezekiel 33 in forum Boat Hardware
    Last Post: 04-03-2012, 08:26 AM
  3. m-ywedge transom saver
    By papyson in forum Mercury Mariner Outboard Forum
    Last Post: 03-18-2012, 01:19 PM
  4. quality transom saver
    Last Post: 01-30-2012, 11:26 AM
  5. transom saver or not???
    By sgms18 in forum Mercury Mariner Outboard Forum
    Last Post: 05-23-2010, 11:28 AM
