bf60 valve clearance
Snoekkop
Hi gents,
what is the valve clearance(lash) for a Honda BF 60 A.
want to check if clearances are within spec.
Got my injectors back, will install them and revert back with results , in regards with my previous post.
thanks in advance.
Hi,
Its fine,managed to get specs and adjusted intake to 0.17 mm(cold) and exhaust to 0.28 mm (cold)
Idles much better and evenly. Exhaust valves were at 0.12 mm, intake were at 0.13 mm.
All i need to do now is test underway with load, and see if it still misfires(hiccups) at higher rpms.
thanks
Hi gents,
Had a fishing trip ( Total 70 Nm) , outboards ran flawlessly,no hiccups , they were prfect.We used 80 liters fuel on the two outboards.
Seems the injectors were dirty and fuel delivery was inconsistent.
Thanks for the help chaps.
