Results 1 to 5 of 5
  1. #1
    Default Coil Locating Ring 317001
    Any known sources? Ebay and boats.net are blank, and my local shop can't get one.
  2. #2
    Join Date
    Sep 2010
    Posts
    20,671
    Default Re: Coil Locating Ring 317001
    A couple of clicks on this site and it will be on your door step.-----Just a little under $100.----Box at the top of this page.----Enter the part #-------I have that tool.----If I was desperate for one I would take a scrap flywheel and cut away most of it so that I could set the coils with a feeler gauge.------Or simply use the coil mounting bosses to set them !
  3. #3
    Kinda forgot this site was also a store..... The alternate part number also opens up some options. Thanks!
  4. #4
    Join Date
    Nov 2011
    Posts
    3,047
    richardsoutboardtools.com
  5. #5
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,462
    The advice of Racer is also very good. When you carefully set coils to the inner edge of chamferr, you rarely will get insufficient clearance. If you get a rub, then it's time to address the stator bushing.
Similar Threads
  1. Replies: 12
    Last Post: 07-17-2017, 05:45 PM
  2. 1977 115HP Piston Ring Locating Pin Acceptable Length
    By nicklanigan in forum Johnson Evinrude Outboard Forum
    Last Post: 02-12-2017, 11:12 AM
  3. Omc tools----317001 and omc tool 0334994----help please
    By BASSBOAT21 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-14-2016, 11:10 PM
  4. 84 115 evinrude piston ring install.. which way does the 1 ring go?
    By comet424 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-12-2015, 10:27 AM
  5. Clamping Ring O ring repl
    By jon_allen in forum Volvo Penta Gas Archive
    Last Post: 07-18-2008, 04:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
