Results 1 to 14 of 14
  1. #1
    Default 1962 Evinrude 3hp gas leak
    Hi, I have a gas leak that looks like it originates from either the fuel knob or where the line connects. I had put plumbers tape on the connection on the fuel line and it worked for a little before it dissolved. The carburetor bowl gasket also looks wet but Iím pretty sure itís also from the line connection since the whole line is wet.
  2. #2
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,490
    Default Re: 1962 Evinrude 3hp gas leak
    Maybe you can tighten the nut on the fuel valve stem packing and see if that helps.
  3. #3
    How old is the fuel line? Ethanol gas can do some damage over time. Might be time to replace it.
  4. #4
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,490
    Think this is all copper or steel line. I have successfully modified these to include a rubber line and small filter. I will see if I can post a picture.
    The lower cowling fits over it very well. Sold this motor for $400 last May, and the family loves it. The young son dumped it completely underwater. I coached them through recovery and drying it out. They got it going again the same day. Now I'm fixing their 9.9 horse Evinrude. Plenty of these old outboards still around here in Northern MN.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  5. #5
    Ah, my mistake. Should've been obvious with the plumbers tape.
    Edit: Does gas dissolve plumbers tape?
  6. #6
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,490
    Not really, but plumbers tape is for use on threads, eh? And these compression fittings don't really leak past the threads, they leak along the tube.....past where the taper/sleeve is supposed to seal.
  7. #7
    It looks like the leak is coming from where it screws onto the tank since it’s completely wet all the way to the top. I’m going to try a rubber o ring to see if that helps.
  8. #8
    And the plumbers tape looked like it had dissolved, it was almost completely gone and only a small piece was left. I’m going to try to get some gas safe plumbers tape because it seems to have worked the best for me.
  9. #9
    I also tried some thread sealant and it worked for like 24 hours before it started leak again. It’s definitely leaking above the petcock too since it still leaks with the gas off
  10. #10
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,490
    How bout this stuff? Make sure you wrap the right direction so as you tighten the fitting, it doesn't come unwrapped. Put a couple layers so it can squish into the imperfections and that allows a better chance to line up the valve with the lower cowling slot.
  11. #11
    I’ll have to try to pick that up somewhere.
  12. #12
    Ok I just put the o ring on it and I had to really crank it down so that the fuel shutoff valve faced straight. It seems to be working, I can’t imagine why it wouldn’t.
  13. #13
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,490
    Good. Got a flat surface to seal instead of pipe/taper threads, eh?
  14. #14
    Join Date
    Jul 2020
    Location
    Virginia, MN
    Posts
    25
    I fixed the same issue on my dads this summer. Found a new fiber gasket at local hardware store, and my go-to sealant for fuel/oil is either Yama-bond or Honda-bond gray liquid gasket maker. It is made for two stroke crank cases.
Similar Threads
  1. 1962 Evinrude 10hp
    By JDTANN in forum Johnson Evinrude Outboard Forum
    Last Post: 04-30-2020, 03:01 PM
  2. In need of prop for 1962 Evinrude
    By RJB31 in forum Propeller Selection and Replacement
    Last Post: 10-14-2015, 09:20 PM
  3. Carb High Speed Needle Valve Leak 1962 10HP Johnson
    By tims_10hp in forum Johnson Evinrude Outboard Archive
    Last Post: 05-11-2009, 02:15 PM
  4. 1962 evinrude V4 75hp
    By jbird in forum Johnson Evinrude Outboard Archive
    Last Post: 05-20-2006, 12:34 AM
  5. 1962 evinrude 75hp
    By andrew in forum Johnson Evinrude Outboard Archive
    Last Post: 06-07-2003, 10:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
