Click for Honda Manuals, Parts and Model Guides!
Results 1 to 4 of 4
  1. #1
    Join Date
    May 2020
    Location
    North Carolina
    Posts
    29
    Default Oil leaking - Honda 225 2002
    Once again I’m having a few issues. I want to say that the motor is running SUPER WELL. Although this last trip I went on a 200 mile round trip. I checked the vitals before and I had the oil filled.
    On the way back, the last 30 mile stretch I get a overheat alarm. Stop and check the oil I notice is extremely low again. Now during the trip when I would stop and tilt motor up I would notice oil around the motor (in the water). I didn’t worry as I thought it was possibly some oil soot from doing an oil change.
    So now I have came home I just can’t see where it’s possibly leaking as I took off the hood and can’t spot anywhere it could be possibly leaking.
    I have also read of possible pan oil gasket giving out due to age? Now if it’s possibly that is it necessary to remove power head or can I come in from the bottom so that?
    OR is there any recommendations of what else it could be or something I can check?
    *recently posted thread of me replacing valve seal
    covers and spark plug seals. Fixed that leaking area. I’m guessing these seals are starting to give after the motor is 20 years old?
    Thank you ahead of time guys! I really appreciate it
  2. #2
    Join Date
    Apr 2018
    Posts
    1,366
    Default Re: Oil leaking - Honda 225 2002
    Take the starter motor off and see if there is oil in the flywheel housing, could have a leaking lower crank seal
  3. #3
    Join Date
    May 2020
    Location
    North Carolina
    Posts
    29
    Quote Originally Posted by iang6766 View Post
    I'll go ahead and check that out when these local fires subside from my house. Is there anything else i can check?
  4. #4
    Join Date
    Apr 2018
    Posts
    1,366
    That's the only thing I can think of that would leak that's not easy to find. Could also be one of the oil pump seals too.Also check the shift shaft seal although this only typically leaks into the engine well when the motor is tilted up.
Similar Threads
  1. 2002 90hp Johnson 4 stroke leaking oil
    By [email protected] in forum Johnson Evinrude Outboard Forum
    Last Post: 05-02-2019, 03:24 PM
  2. Mercury 2002 - 125hp leaking oil when tilting up engine
    By Rolle85 in forum Mercury Mariner Outboard Forum
    Last Post: 07-22-2018, 11:22 AM
  3. 2002 Honda BF225 - Honda Service Bulletin #56
    By brian__c in forum Honda Outboard Forum
    Last Post: 07-13-2014, 09:03 AM
  4. Fuel leaking into the oil 5.7L Mercruiser 2002 570 hours
    By lenny35 in forum Mercruiser Sterndrive Forum
    Last Post: 08-04-2013, 08:43 AM
  5. Leaking lower unit oil on garage floor 2002 4.3 L
    By mrober11 in forum Mercruiser Sterndrive Forum
    Last Post: 02-27-2011, 06:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
