Results 1 to 21 of 21
  1. #1
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Default 1989 Johnson GT150 - Power Trim & Tilt
    I'm new here and could use some help. What should I inspect first when I 'trim out' (not under power) my motor and it make an intermittent scratchy/squeaky sound instead of the normal constant sound of the cylinder trimming my motor out. It's like it lost power to raise the motor. It'll "catch" and then continue to raise motor and that scratchy/squeaky sound goes away. It will trim all the way down like normal. Try to trim it out again and it's like it doesn't have the power to raise the motor. Pardon my lack of wording this issue correctly. I've looked at my manual and it's over my head of understanding what to look for. I don't have a good mechanic background or even a decent understanding of hydraulics, I'll get there with some help and study.Thanks in advance for any help.
    Jack Lowe
  2. #2
    Join Date
    Apr 2010
    Posts
    4,947
    Default Re: 1989 Johnson GT150 - Power Trim & Tilt
    Raise the motor all the way up and check the fluid level . If this helps, do it about 10 times.
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    15,853
    Yep, the first thing to do is as Boobies statement... making sure that the reservoir is full when the tilt is completely in the up position.
    Adding to that "Scratchy, Squeaky" sound and the "Loss of Power"... that could very well be a build up of salt corrosion build up in the top nylon bushing of the "Center Lift Cylinder" or the nylon bushings of the engine's main "Pivot/Steering Tube". The salt buildup at those two areas can get so bad that the unit items become one piece, locked tightly, unable to swivel.
    We occasionally have questions. If you fail to answer, it may affect ours.
  4. #4
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Thanks Boobie, guess I'll need to find out where exactly one adds fluid. When you say "do it about 10 time"...what does that mean? Raise the motor, add fluid, lower motor all the way down (with/without putting bolt back in to fluid refill spot ?) and then 'repeat'...until I get a 'normal sounding' trim/tilt sound? Is there any need to drain all the fluid out? Sorry for my lack of using the right lingo. Thanks for taking the time to help me out!
  5. #5
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Thanks joereeves. This 'salt corrosion' buildup you mentioned, my boat has never been in saltwater so would this possibly be just a 'corrosion' issue, if it's that, due to age of the motor. I've had this boat since 1997 and the Trim/Tilt assembly hasn't ever been in need of being looked at for problems. It is 23 years old now and understandable that parts/pieces do wear out. Thank for the time to help me out!
  6. #6
    Join Date
    Feb 2001
    Location
    Posts
    15,853
    Fluid reservoir "fill/level" is the large regular slotted screw/seal assy approximately half way up the reservoir which is atop the starboard (right) side of the PTT unit. Fill to overflowing.
    Always replace that screw before lowering the engine as otherwise, the fluid will be forced out... really makes a mess! And yes, it's a repeat performance in filling that reservoir should any air be trapped in there.
    If after lowering and raising the engine a few times... and in removing that fill screw, you find the fluid level to still be full to overflowing... that's about as full as you're going to get it.
    My explanation of the squeaking has proven (to me) to be the average cause (Nylon Bushings) but it has always been related to "Salt Corrosion". I've never encountered a bushing problem via fresh water... possible I suppose.
    The noise could also be a failing internal piston of the center lifting cylinder, or a dry bushing area of the electrical motor. Have a helper work with you in trying to define just where that noise is coming from.
    Last edited by joereeves; 10-26-2020 at 10:11 AM. Reason: Spelling & revising info
  7. #7
    Join Date
    Sep 2010
    Posts
    20,684
    Oxygen JOINS with aluminum to form ALUMINUM OXIDE.----That is the white powder that you might see.----So with oxygen joining up there is more material in the holes than before.------That is one reason bushings will jam tight.-----More of a problem in salt water than fresh water.----If noise persists after topping up the fluid you might investigate.
  8. #8
    Join Date
    Feb 2001
    Location
    Posts
    15,853
    Quote Originally Posted by racerone View Post
    Good one racer... never gave that one a thought.
  9. #9
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Good morning, what's a good preventative measure one could take to reduce buildup of Aluminum Oxide on surfaces where they would build up? Regular cleaning/washing comes to mind. If there is an excessive buildup, what product (home brew or 'official cleaner') might you recommend. I should be getting my OMC Trim & Till PWS fluid today and will give this a try. A little reading and re-reading and all of y'alls help is working. My 'boat guy' is in FLA, i'm in TN, for the Winter, so I'm going to do what I can to resolve small issues. Thank you for taking to time to share, much appreciated!
  10. #10
    Join Date
    Sep 2010
    Posts
    20,684
    Aluminum oxide has to be scraped out.-----A sealer can be used to keep air and water out of the areas where the build up occurs.-----That is if in fact jammed bushings are the problem.
  11. #11
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Thanks, gotcha...seems that once it's there, it's too late. It doesn't appear that I've let those areas on my motor reach that point, just curious what might work, outside of a good regular cleaning.
  12. #12
    Join Date
    Feb 2001
    Location
    Posts
    15,853
    Quote Originally Posted by JACK LOWE View Post
    Anti Corrosive Grease as a preventative would be my choice. In my 30+ years with OMC, I've found engine after engine whereas those grease fittings were neglected terribly.
    Your boat guy is in Florida huh?... My home for the past 43+ years (Tampa Bay Area), almost used to it now!
  13. #13
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,471
    Hello, how's my mentors doing today. Between you 2 guys, we could solve about any problem out there.....then add Boobie and it's GOTTA work.
    Here's what my brother, Steve, in Miami recommends. He has been boating for 50 plus years too, and a decent mechanic and tradesman. Retired trial lawyer with a solid grasp on the "real world". These are great products to cover what you guys are talking about.
    https://nationalsupplydirect.com/whi...lubricant.html
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  14. #14
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    National Supply Direct....got it bookmarked, appreciate the link!
  15. #15
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    4,767
    Put a dab of grease on the thrust pads on midsection. It where trim rods contact midsection. When dry they creak,pop as pads get a groove in them and cause trim rods to bind.
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  16. #16
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Appreciate that fatzbullet, I'll check that out...
  17. #17
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,471
    Great suggestion. They can make a ton of noise......don't overlook them.
  18. #18
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Yes sir, he and his wife take their 5th wheel to a Clewiston for the Winter months and fish Okeechobee. Super nice guy and knows his stuff. Only one to ever work on my boat (20+ years now) and I'm very hesitant to let anyone else work on the motor. I noticed your remark about "grease fittings" and being neglected. Many of mine look terrible and before I reinvent the wheel. Would you be able to tell me what size 'zerks' are on my motor (yes, I admit that I just learned what those are called today). I've You Tube'd a few good videos about all this today and while I'm reading my service manual, I haven't found (yet) anything about these zerks. Appreciate your (and everyones) help... I'm learning
  19. #19
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,471
    Think they are a 6mm x 1. Did you know spark plug threads are metric? They are NOT 9/16" x 20 as many people think......maybe they just don't care? Just a little tidbit of information for you.
  20. #20
    Join Date
    Sep 2020
    Location
    Tennessee
    Posts
    9
    Quote Originally Posted by timguy View Post
    Thanks timguy, appreciate you sharing... I didn't know about spark plug threads either... Reckon I'll remove a zerk, which is a funny name, and take it to a local auto place and see if they have 'em, hopefully they will. I got my trim/tilt fluid and with everyone's help who has shared with me on what to check and grease, I should be good to go, again, I hope.
  21. #21
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    4,767
Similar Threads
  1. 1989 Johnson gt150 - need to find the timing value for this motor and set it
    By kknopp26 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-05-2016, 09:32 PM
  2. 1989 Johnson 200 hp trim and tilt question
    By Cessna340 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-28-2016, 10:55 PM
  3. 1989 GT150 johnson
    By blackrock in forum Johnson Evinrude Outboard Archive
    Last Post: 07-05-2009, 04:40 PM
  4. 1989 Johnson GT150 missing until it warms up
    By Jason Owens in forum Johnson Evinrude Outboard Archive
    Last Post: 08-23-2007, 11:57 PM
  5. 1989 Johnson GT150 missing at high speeds
    By Jay Owens in forum Johnson Evinrude Outboard Archive
    Last Post: 07-19-2007, 03:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
