Hi everyone, I’m kind of a noob to outboard motors although I have worked on many other small engines in the past.
I have a 1960-1963 Evinrude lightwin 3hp outboard motor model number 3042b. I bought it from a guy who had it running 3 months ago and it *should of been* an easy fix
When I first got it I took off the carburetor bowl. It was barely dirty so I just cleaned it out and I made sure the float was level etc but I did not go further than that, I took out the jets and made sure they were clean. It has spark and compression and fuel. When I went to start it the first time it took a couple pulls but would run and no matter how much you messed with the setting it didn’t run longer than 10 seconds. It would start first pull then run for a couple of seconds then die. After a while it wouldn’t start 99% of the time, I did get it to hit once. I checked to make sure there was fuel in the bowl, there was. The carb did leak a little but I think it was due to it being on an incline. The spark on the top cylinder was strong yet it was an orange/purple spark and the bottom cylinder had nice blue spark. Could it be the spark plugs? They are pretty dirty. Any other tips would be greatly appreciated. It also needs a new impeller
