Results 1 to 21 of 21
  1. #1
    Default 1957 18hp Fastwin
    Hi all. Starting to plan for a new restoration. I believe I'll need a new powerhead for this one. It looks like it go water in the block. What years of Johnson or Evinrude are identical with the '57 Evinrude 18?
  2. #2
    Join Date
    Sep 2010
    Posts
    20,700
    Default Re: 1957 18hp Fastwin
    Up to about 1976 might fit.
  3. #3
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Got some beauties here. PM me if you can't find a good one at a fair price.
  4. #4
    Join Date
    Nov 2011
    Posts
    3,049
    Powerhead base bolt pattern was changed around 1959-ish. Also puddle drain system change around 1967-ish and again 1972-ish. Do your homework.
  5. #5
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Got a PM for you. I have a sweet 18 powerhead too....it's a 1957 or 58.
  6. #6
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Hi, can a 1962 powerhead work? Wasn't happy with one spot in that '58 cylinder. I think it will work but asking confirmation from a mentor out there.
  7. #7
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Here is the 62 Johnson.....will this work for our shinola project?
    One bolt is broke if you look closely. I will fix that up for you.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  8. #8
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Hey Gator, will this work on that 57? Thanks.
  9. #9
    Join Date
    Nov 2011
    Posts
    3,049
    My computer with that sort of info on it puked yesterday. But I think the answer is no.
  10. #10
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Thanks, Gator, hope you can recover your information. A loss of a computer can be devastating.....even a cell phone loss. Got Cloud on this Verizon phone. Guess I'm gonna have to set a 57 next to this 62 and compare. Got 3 other 57's here....that I picked up with rust. Others are good and shouldn't be parted out. Have a few newer 18's too for parts. Racer says they could work, but didn't sound too certain. Gonna have to call Tim's Outboard, might be they have swapped them around.
  11. #11
    Join Date
    Nov 2011
    Posts
    3,049
    I believe the 1957 base pattern is like this one. Ignore the note---picture was saved for another purpose. Now using my laptop, whatta pain.
Name:	Drain Valves 3.jpg
  12. #12
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Thanks. Looks quite a bit different, especially around the crankshaft area. The 5 bolts under the cylinder might line up, but that's it.
  13. #13
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Does anyone know if a '52 14 hp powerhead would work? Got a nice one here too. Probably should fix the motor, but it's missing a lower cowling on port side. Haven't been able to find one.
  14. #14
    Join Date
    Nov 2011
    Posts
    3,049
    Nah, a 14 is a whole different critter.
  15. #15
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Okay....kinda thought so, it has separate timing/throttle.....remember them? Very fast for 14 hp. There is a sweet running one on YouTube. I like the front feed fuel line too. Here I thought I had a nice powerhead for the OP. Interchangeability is not as broad as one may think. I have lots of these around, but they are too nice to parts out. Have another source yet, OP, so give me a couple more days.
  16. #16
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Dan, at Tim's Outboard in Hackensack said he thinks they made the mounting change when OMC (Johnson/Evinrude) went to the single line tanks. He thinks he has a power head for me but is going to run it by Mike who is more into the vintage outboards.
  17. #17
    Join Date
    Nov 2011
    Posts
    3,049
    Both tank & fiberglass hoods came into the issue. Actually the hood, mostly.
  18. #18
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Right, Dan mentioned that exactly. The older mounting pattern gave much better access to all parts, then came the 59 and up fiberglass cowling......Note: With the old, tighter fitting flip up cowling design, they never got dropped or blew off going down the road. So in review, we have decided that the last year for pressure tank was 59, but also the first year for new bolt/mounting pattern. Right?
  19. #19
    I've found a 58 Johnson 18 powerhead for a good price. timguy, your PM box is full again. Please PM me a picture of the 9.5 head.
    thanks.
  20. #20
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Okay will do. Dan said he thinks 57 and 58 only on the 18's. Will drain box down some, thanks.
  21. #21
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,492
    Even Dan and Mike at Tim's Outboard are sold out of those years of 18's. When I get some time I'm gonna look how to modify the 1961, 62, 63 blocks to possibly fit. I have at least 5 good ones here. Since I alum weld MIG, I think it can be done.
Similar Threads
  1. 1957 Evinrude Fastwin 18hp
    By flylikechris in forum Johnson Evinrude Outboard Forum
    Last Post: 03-19-2018, 09:14 PM
  2. Fastwin 18hp timing
    By Nucad in forum Johnson Evinrude Outboard Forum
    Last Post: 08-11-2017, 11:15 AM
  3. 1957 Evinrude Fastwin 18hp Fuel/oil Mixture Ratio
    By jbryant1962 in forum Fuel / Oil Mixture Ratio
    Last Post: 04-02-2014, 02:55 PM
  4. 18hp evinrude fastwin
    By bgharb2 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-08-2009, 05:45 PM
  5. 1957 Evinrude 18 Hp fastwin
    By kenskip1 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-09-2007, 01:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
