Results 1 to 12 of 12
  1. #1
    Default 95 Mercruiser 350 Magnum Tournament Ski engine oil
    Serial #OF652552. I've been using Quicksilver 25W-40 FC-W conventional for $24/gal. from Walmart. Bass Pro sells their store brand with the same viscosity and FC-W rating for $13/gal. Both are NMMA-approved.
    So, is this a “You get what you pay for” situation, or should I use the Bass Pro?
    Many thanks for your help, PW
  2. #2
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    3,511
    Default Re: 95 Mercruiser 350 Magnum Tournament Ski engine oil
    FC-W is a specification that establishes minimum performance for both engine oil viscosity (vs temp) and corrosion resistance ( additives) ..... note....minimum levels. Usually a "house brand" is just as good as some other vendors normal product. The question(s)... who is the actual house brand's supplier.... and to what extent does the product exceed the minimums of the specification.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
  3. #3
    Thanks for yr reply. According to NMMA certification:
    Certificate # Product Supplier
    Somehow I don't think Mercury has its own refinery, chemistry and packaging operations. And Bass Pro identifies their supplier, which is a global producer of automotive and specialty lubricants. Looks like I'm going with Bass Pro.
  4. #4
    Either will be fine. You can also run shell rotella 15w40. Also about the same price Per gallon.
  5. #5
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    6,071
    Oh No... Make sure you save that $11.00
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    16,993
    Love that Rotella!
    Jeff
  7. #7
    Quote Originally Posted by Docksidemarineservices View Post
    On 3/31, I took a 30% pay cut to keep my job and medical benefits. Now I make less money than I did 20 years ago. Glad you can afford to waste money wherever and whenever you please. Growing up in a house where ends just barely met, I never learned that habit and I'm glad of it. Just keep your smarta&# remarks to yrself.
  8. #8
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    1,996
    Then sell the boat if you're so hard up. Really, it's hard to justify keeping it if it is such a drain on your finances.
    But to answer the question, you cannot go wrong using straight 30 wt in the gallon jugs from Walmart. As long as it meets API requirements for SJ (which covers your engine year) you're OK. The current API rating is SP as of March 2020. In a marine engine, which gets oil changes far more frequently that a car engine, you will be fine using the straight heavy duty stuff. You don't need a multi-viscosity since you are not operating it in winter conditions.
    Practicing the ancient art of ren-ching
  9. #9
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    6,071
    Whatever.
    Chris
    Jersey Shore.
  10. #10
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,602
    Quote Originally Posted by pwskicat View Post
    For about the same cost and from the same place (Wally world). Purchase Mobile One 15w-50w synthetic oil.
    I have been using Mobile One in all my engines for well over 30 years, Boat (1987) 15w-50w, Truck 10w-30w (1998), Motorcycle 20w-50w Vtwin
    I also use Mobile One 15w-50w for all boats I service.
    Jack
    Mass.
  11. #11
    1) I'm not hard up, just thrifty. Sometimes I save a little money, or when my buddy was about to pay $600 for a new rudder for his 25 year-old ski boat, I saved him a lot with a salvage piece for $200. People have hobbies. One of mine is saving.
    Z) The reason I can keep the boat is because I've always lived well below my means. It's not a hardship, it's financial security. When the sewer line at my house broke and the $4K repair bill came due, I wrote the check without a care.
    3) I wasn't talking to you.
    D) Know I can always count on yr sympathetic ear. /S
  12. #12
    Thank u, sir.
Similar Threads
  1. 95 Mercruiser 350 Magnum Tournament Ski: Got to WOT!
    By pwskicat in forum Mercruiser Sterndrive Forum
    Last Post: 08-17-2020, 07:22 AM
  2. 95 Merc 350 Magnum Tournament Ski Spark Plug Thread Repair
    Last Post: 07-12-2020, 05:59 PM
  3. 95 Mercruiser 350 Magnum Tournament Ski TBI fuel pump replacement
    Last Post: 07-12-2020, 08:11 AM
  4. 1995 Mercruiser 350 Magnum Tournament Ski EFI: Throttle Body cleaner OK?
    By pwskicat in forum Marine Power Engine Forum
    Last Post: 07-08-2020, 03:49 PM
  5. 1995 350 Magnum Tournament Ski Throttle Body EFI Fuel Strangulation
    Last Post: 06-19-2019, 11:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
