Click for Ford Lehman manuals!
Results 1 to 3 of 3
    Default Anti freeze leaks from Thru-hull strainer when on the hard for bottom painting.
    I could use some help on a problem that arose when we hauled Encore out to bottom paint. The hull was fouled, but no sign of blisters thankfully. However, just before we put Encore in the slings, the yardman asked me if I knew that antifreeze was dripping out of the port raw water engine intake. I looked, and sure enough, there was a steady drip, having filled up half of an empty paint can. We put Encore in the water, as we had to get it out of the yard, and I decided that we could motor home on one engine (which we did). Once home, I opened the thru-hull strainer and nice green anti-freeze began to flow out. Interestingly, with Encore in the water, there didn't appear to be any anti-freeze leaking from under the boat. (verified by diving under with a mask). So that's the set up.
    Now I need some suggestions. Where besides the heat exchanger could the closed system cooling mix with the raw water? I'm at a loss, and could use some suggestions.
    Thanks,
    Jim Lanza
    Punta Gorda, FL
    Default Re: Anti freeze leaks from Thru-hull strainer when on the hard for bottom painting.
    I failed to mention that I have twin Lehman 135 diesels. Sorry
    Sep 2008
    Maryland - USA
    8,515
    I'd check the port heat exchanger...if its leaking, it should (have been) be low. if so, I'd pressure test it...if you don't have the tester, most any radiator shop should be able to test it...they should also be able to repair it if in otherwise decent condition...
    I'd also be inclined to check the raw water pump...if its passing antifreeze when stationary, its likely in need of service, too...
  1. Switch to through hull strainer
    By Chris Rohde in forum Volvo Penta Gas Engine Forum
    Last Post: 05-04-2017, 12:21 PM
  2. Anti freeze?
    By jerry and sons in forum Crusader Marine Engine Forum
    Last Post: 03-25-2011, 04:54 PM
  3. Anti Freeze
    By truszip in forum Mercruiser Sterndrive Archive
    Last Post: 10-23-2008, 03:38 PM
  4. Through hull strainer direction
    By smaassen in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 04-25-2008, 09:01 AM
  5. Anti Freeze
    By W. Sadler in forum OMC Sterndrive and Inboard Archive
    Last Post: 10-18-2006, 07:06 AM
