2005 twin 150s
Starboard engine keeps overheating
New Pump kits have 20 hours
Replaced thermostats - popit valve(dump valve or whatever its called) and swapped out sensors with port engine. Cleaned intake screen and salt awayed it multiple times.
If I hook up the water hose and split it between the earmuffs and the flush hose it is fine. As soon as I back off pressure to flush hose and more to muffs it overheats. Thermos in or out same result.
Gota be a bad impeller/pump???
Thoughts
Thoughts
