Hello all. New to this forum. Looks to be a lot of great info on the board, I look forward to learning and sharing.
My current project is a '73 9.5 Evinrude. Seems to have a few issues. Might have gotten in a little too deep this time. My current problem is a broken bolt in the lower unit. I was dropping the gearcase to replace the water-pump and check seals/lube/ etc. and one of the bolts sheared off. The cap broke off pretty cleanly, but left most of the hole in the lower unit filled with corroded bolt, so I'm unable to separate the lower unit. I just dealt with the same thing with one of the cylinder head bolts, but I had access to drill it out with LH drills. No luck here due to the anti-cavitation plate blocking drill access. Anyone dealt with this that could provide advice? I'm currently soaking several times a day with PB-Blaster, and heating up the lower case with a propane torch to see if expansion could draw more of the Blaster in.
This project is likely a long one, and I'm sure I'll reach out for more along the way. Some of the known issues are:
1. throttle is frozen. Not sure if it's in the handle, gear, or where.
2. Lots of white caked powder in the water passaged in the head, it was completely blocked. Mostly easy to scrape out but some hard sections. I'm sure this was a salt water motor that appears to not have been taken care of.
3. Water in the gear oil when I drained it. At least it held oil. I'm sure seals will take care of this one.
4. Fuel pump needs replacing. Can't find OEM. Would a more modern 9.9 pump work? I see some on Amazon and comments that they fit '65 9.5 motors, so might work on mine.
I really wish I had checked compression before I started disassembly, but one of the plug holes was stripped (helicoil will fix) and i had to remove the head anyway to repair that. I'll probably put that back on and check compression before I go further.
Thanks for reading.
Shinola.
Thanks for reading.
Shinola.
